Hydraulic brake issue
YORKSHIRENEO
Got the above fitted to my baja. Problem is there are screw caps that are use to attach the pipe to the calipers and reservoir and one of them is knackered. Ive searched all over t'internet but cannot find them anywhere. Does anyone know the proper name for these "screw caps" and/or know where i can get a replacement? Will post pics if need be later Cheers
Bought them from asiatees website, marketed as a Topcad product. They are little brass coloured screw caps. You feed them over the hydraulic pipe, connect the pipe to the nipple and then screw down the caps to seal the pipes on. Cant get pic atm but they're not the ones above. After a bit of thinking i may be able to swap it out for a sealed one. Just means swapping it over if i need to refill/bleed the system.
These are the ones, the little caps with the chequer style finish
Edited by YORKSHIRENEO
Heres the push fittings
http://rc-car-online.de/shop/en/250-universal.html
The screw on type you have a recall are the same as Lauterbacher ones.
5 and 6 in this link for the part numbers
http://www.lauterbacher.net/xtc/product_info.php?info=p4399_Rear-hydralic-brake-overview.html
