haskins104 Posted August 25, 2014 Share Posted August 25, 2014 hi all still a little new to nitro cars, i have a dhk optimus gp and seem to be using a lot of nitro, car seems to be running ok but from some vids I've been watching on the tuning of a nitro engine seems like I've not got enough smoke out of the exhaust yet which means i need to richen the fast needle abit more but then this would mean i would be using more fuel? or also would the car use more fuel if the idol screw is open to much but still keep and idol?. Quote Link to comment Share on other sites More sharing options...
Tamiyacowboy Posted August 25, 2014 Share Posted August 25, 2014 (edited) what do you mean by using to much fuel. ok lets do some quick checks, very simple but we can find out if the car is running to rich. when a car has to much fuel going in and not much air mixing in, the car CAN smoke alot. not will but can, this is different for every engine. so pick up you machine, and smell the exhaust outlet, does it smell oily like ? do you notice when the car is running if it spits liquid out from the exhaust, this may be a dribble when you pick up and tip car, or its like a fine mist spray all over the rear of the car and where exhaust exits shell. THESE are two pure signs the car is running a to rich mix, so it needs taming down a little ( you adjust the flow rate for the fuel ). Tuning , is adjustment of the flow rate of the fuel and the air mix going in. when tuning your wanting maximum compression and ignition but using a low amount of atomized fuel and air . the seasonal weather affects our nitro models to. summer tuning will not work for winter, so you will find in winter a car is much harder to start for one the cold and the second is the fuel air mix, to much air ( winter the air is colder and more dense than summer ) so you tend to buff the fuel rate a tad, when your really wanting a little less air mix. if you can pop outside, start up truck and take a video, upload and post here so guys can hear your nitro running and take off and come to idle. the sound is so distinctive they can tell if its to rich or to lean. Edited August 25, 2014 by Tamiyacowboy 1 Quote Link to comment Share on other sites More sharing options...
haskins104 Posted August 25, 2014 Author Share Posted August 25, 2014 what do you mean by using to much fuel. ok lets do some quick checks, very simple but we can find out if the car is running to rich. when a car has to much fuel going in and not much air mixing in, the car CAN smoke alot. not will but can, this is different for every engine. so pick up you machine, and smell the exhaust outlet, does it smell oily like ? do you notice when the car is running if it spits liquid out from the exhaust, this may be a dribble when you pick up and tip car, or its like a fine mist spray all over the rear of the car and where exhaust exits shell. THESE are two pure signs the car is running a to rich mix, so it needs taming down a little ( you adjust the flow rate for the fuel ). Tuning , is adjustment of the flow rate of the fuel and the air mix going in. when tuning your wanting maximum compression and ignition but using a low amount of atomized fuel and air . the seasonal weather affects our nitro models to. summer tuning will not work for winter, so you will find in winter a car is much harder to start for one the cold and the second is the fuel air mix, to much air ( winter the air is colder and more dense than summer ) so you tend to buff the fuel rate a tad, when your really wanting a little less air mix. if you can pop outside, start up truck and take a video, upload and post here so guys can hear your nitro running and take off and come to idle. the sound is so distinctive they can tell if its to rich or to lean. thanks for fast reply. can't take car out at min cause it is raining heavy, but had it out yesterday and i seemed to use a lot more fuel than my brother but like u said he's is a different model, yesterday i really noticed an oily mist all over the back and spoiler of the car like it was lightly coated in oil. also once it first starts it firstly revs then dies down but does this very quickly . also sounds quite load when at idol. Quote Link to comment Share on other sites More sharing options...
jordanp Posted August 25, 2014 Share Posted August 25, 2014 (edited) what pipe have you got and check your pipe gasgets to see if its leaking that could be the reason why its using more fuel Edited August 25, 2014 by jordanp Quote Link to comment Share on other sites More sharing options...
haskins104 Posted August 25, 2014 Author Share Posted August 25, 2014 what pipe have you got and check your pipe gasgets to see if its leaking that could be the reason why its using more fuel just the standard pipe, new gaskets already fitted so not them. Quote Link to comment Share on other sites More sharing options...
haskins104 Posted August 27, 2014 Author Share Posted August 27, 2014 (edited) more issues today any help will do, car seems to sound real loud when at idol and slowly starts to creep forward. Edited August 27, 2014 by haskins104 Quote Link to comment Share on other sites More sharing options...
haskins104 Posted August 27, 2014 Author Share Posted August 27, 2014 https://plus.google.com/113912221870057070700/posts/6xcMR2esN9e https://plus.google.com/113912221870057070700/posts/LYyRMxzZpgP need help with this. sounds really load and slowly moving forward was not doing this yesterday. Quote Link to comment Share on other sites More sharing options...
jordanp Posted August 27, 2014 Share Posted August 27, 2014 your idle sounds lean which is making it idle higher and hence the clutch is engaging also id lean out the high speed needle just a tad as its spewing alot of smoke when you throttle 1 Quote Link to comment Share on other sites More sharing options...
haskins104 Posted August 28, 2014 Author Share Posted August 28, 2014 cheers bud will get this hopefully sorted today Quote Link to comment Share on other sites More sharing options...
