mightymini-5 Posted August 24, 2014 Share Posted August 24, 2014 (edited) hello all just got my self a scout looking at modding slowly and a little have took it out today and keep catching the diff guards so took the off and ws looking at cutting mounting points off is this advisable ie do they cut off ok or do i need a little as dont want to leave a hole in casing many thanks in advance shaun Edited August 24, 2014 by mightymini-5 Quote Link to comment Share on other sites More sharing options...
Trans4Mation Posted August 24, 2014 Share Posted August 24, 2014 Yes you can cut them right down to the case I used a barrel sander on them once cut off to get the same shape as the diff case if you go right down you will notice a small square hole into the case just fill it will hot glue, if urs is a new scout strip it grease all the axels an gearbox as there is hardly any in them if any from new , why you have the diffs case in half I use aruldite on the little holes if you don't fancy using hot glue gun. 1 Quote Link to comment Share on other sites More sharing options...
mightymini-5 Posted August 24, 2014 Author Share Posted August 24, 2014 yes mate is new !!!!! cheers Quote Link to comment Share on other sites More sharing options...
Trans4Mation Posted August 24, 2014 Share Posted August 24, 2014 Deffo strip it there shocking , I've had one since before they came out the shops it was bone dry . It's still going we'll only broken a drive shaft but tig welding sorted it better than factory lol . Enjoy running & modding it . Quote Link to comment Share on other sites More sharing options...
nr73 Posted August 25, 2014 Share Posted August 25, 2014 (edited) Cutting the bumper mount lugs off helped with clearance on mine. If you do nothing else, buy some 22mm lead strip off eBay and add weight to the wheels. I added 1.3m in the front each and .7m in the rears. Its up to you whether you want to start modifying the shocks with fuel tube etc, but an easy quick mod is to add two cable ties above the rear left shock collar as it counteracts the torque twist. As mentioned above, my diffs were bone dry too. I stripped both, greased them and did the centre transfer case too in about 1.5 hrs. Edited August 25, 2014 by Neil Robinson Quote Link to comment Share on other sites More sharing options...
Theodore Bagwell Posted August 25, 2014 Share Posted August 25, 2014 When cutting these mountings be careful with the centre one,if you cut it too much you will end up with a whole in your diff,mind you it is handy for putting the grease in. Quote Link to comment Share on other sites More sharing options...
nr73 Posted August 25, 2014 Share Posted August 25, 2014 I just cut the ones at each side that protruded down from the axle. Left the centre one, doesn't seem to get in the way. Quote Link to comment Share on other sites More sharing options...
mightymini-5 Posted August 25, 2014 Author Share Posted August 25, 2014 all done inc grease in diffs and gbox now thanks all shaun Quote Link to comment Share on other sites More sharing options...
mightymini-5 Posted August 30, 2014 Author Share Posted August 30, 2014 does anyone know what metal/ally arm will fit maverick scout servo cheers shaun Quote Link to comment Share on other sites More sharing options...
ghazghul Posted August 30, 2014 Share Posted August 30, 2014 Any 25T (futaba). It's quite long though, the axial ones are expensive. Blacksmith products sell cheaper ones and helpfully list lengths on them... Quote Link to comment Share on other sites More sharing options...
