babylon Posted August 21, 2014 Share Posted August 21, 2014 It's said that the cloners just copy, We know that's not strictly true, What with KM'S 4WD Baja, But it's possible This is going a bit far Not to sure if people will be lining up round the block just to stick this on the side of there Baja to get a reverse gear. Quote Link to comment Share on other sites More sharing options...
Nitroholic Posted August 21, 2014 Share Posted August 21, 2014 If it's reliable and durable .... I can see it selling a few units. Not to 5B owners, as it looks hideous .... but if you have a 5T or 5SC, it's all hidden under the shell where nobody will see it. My biggest issue with this would be the need for a 4 channel radio to use it if you still want a remote killswitch. I'd rather have the killswitch than reverse, as I have had reverse on nitros and found it more of a gimmick I rearely used and a reliability weakpoint when you shift gears by mistake. What you really want with this is the old Savage reverse mixer unit. Allows you to use the brake for reverse. Quote Link to comment Share on other sites More sharing options...
Noj Posted August 21, 2014 Share Posted August 21, 2014 Having reverse on the bl, not something that gets used much tbh, only really handy for straightening up on a start line, or pushing gassers uphill backwards Quote Link to comment Share on other sites More sharing options...
