yoodoo Posted August 17, 2014 Share Posted August 17, 2014 Does anyone have decent tarmac set up for a TC3? I had thought mine was ok but it's pretty arse end happy. Cheers Quote Link to comment Share on other sites More sharing options...
ta05 Posted August 18, 2014 Share Posted August 18, 2014 If it was working ok before but not now then I would first suggest to check your differential tightness. And that no shocks are leaky. Quote Link to comment Share on other sites More sharing options...
ch!ef Posted August 18, 2014 Share Posted August 18, 2014 raise the centre ball stud for the camber link by 1mm-2mm.(not the 1 on the hub the 1 on the chassis) see if that helps. Quote Link to comment Share on other sites More sharing options...
yoodoo Posted August 18, 2014 Author Share Posted August 18, 2014 If it was working ok before but not now then I would first suggest to check your differential tightness. And that no shocks are leaky. Thanks for the answers fellas.I have noticed my diff's are loose.When I tightened them they felt notchy! They have been rebuilt with new plates though? Quote Link to comment Share on other sites More sharing options...
BenK Posted August 19, 2014 Share Posted August 19, 2014 (edited) If you fitted new plates it won`t do if the diff balls aren`t replaced as well. Also run the battery at the rear and go 2deg camber at the back. Edited August 19, 2014 by BenK Quote Link to comment Share on other sites More sharing options...
yoodoo Posted August 22, 2014 Author Share Posted August 22, 2014 Another top answer..thanks. Quote Link to comment Share on other sites More sharing options...
