tingtong333 Posted July 27, 2014 Share Posted July 27, 2014 Hi everyone, ever since I fitted an Alza slipper locker to my Savage Flux, the pinion gear keeps coming loose. The grub screw is still tight in the pinion gear and I have used blue thread locker as well. What am I doing wrong? Many thanks for any replies. Quote Link to comment Share on other sites More sharing options...
Hyper-d Posted July 27, 2014 Share Posted July 27, 2014 Try red thread lock, I believe it gives a stronger hold Quote Link to comment Share on other sites More sharing options...
atom3624 Posted July 27, 2014 Share Posted July 27, 2014 If you use blue thread lock, it should be fine. Leave it at least 30 minutes - overnight is preferred - to set properly. If you start running straight after, it won't have enough time to set. If you use more permanent thread locks, like red, then ensure the grub screw is in very good condition and bear in mind you might even need heat to remove it if/when you want to in the future. Al. Quote Link to comment Share on other sites More sharing options...
tingtong333 Posted July 27, 2014 Author Share Posted July 27, 2014 That's what I have been doing leaving it overnight to cure properly, but I've lost the grub screw now and it's the only spare part I haven't got! When I get some more grub screws I'll degrease the pinion gear properly this time and try again and I'll order some red thread locker aswell! Quote Link to comment Share on other sites More sharing options...
atom3624 Posted July 28, 2014 Share Posted July 28, 2014 Hi everyone, ever since I fitted an Alza slipper locker to my Savage Flux, the pinion gear keeps coming loose. The grub screw is still tight in the pinion gear and I have used blue thread locker as well. What am I doing wrong? Many thanks for any replies. Going back to the original message, are you sure the grub was actually tight on the shaft, or just in the thread? Might not have been tight on the shaft. Al. Quote Link to comment Share on other sites More sharing options...
SchrodeMode Posted July 28, 2014 Share Posted July 28, 2014 Also make sure that it is tight on the flat part of the shaft, I've seen people tighten it down on the rounded part of the shaft. 1 Quote Link to comment Share on other sites More sharing options...
tingtong333 Posted July 28, 2014 Author Share Posted July 28, 2014 Also make sure that it is tight on the flat part of the shaft, I've seen people tighten it down on the rounded part of the shaft. I'm sure that's where I've been going wrong. As soon as the new grub screws arrive Ill give it a try. Many thanks for the replies guys! Quote Link to comment Share on other sites More sharing options...
Noj Posted July 28, 2014 Share Posted July 28, 2014 Speaking from experience, red threadlock and pinion grub screws are not a good mix. You can mark where the grub sits, then dremmel a small notch in the shaft for the grub to sit in... 1 Quote Link to comment Share on other sites More sharing options...
yoodoo Posted July 29, 2014 Share Posted July 29, 2014 Another good pointer is what I do.If you have a grub with a pointed end,file it flush so there is more surface to grip. Quote Link to comment Share on other sites More sharing options...
