vortex666 Posted July 20, 2014 Share Posted July 20, 2014 Unlucky days for my truck,went out for a run,after about 4hours of fun my engine died while running..flywheel is stuck,can't hear the piston going up and down..cloud it be the conrod?piston ring?any ideas before i strip it down?here is the videohttp://youtu.be/T5FNZfACH8U Sent from my iPhone ? using Tapatalk Quote Link to comment Share on other sites More sharing options...
kangarilla Posted July 20, 2014 Share Posted July 20, 2014 its broke Quote Link to comment Share on other sites More sharing options...
mini-z-awd Posted July 21, 2014 Share Posted July 21, 2014 worst case it`s a new head piston and ring but you wont know until you take it apart but i will say it could just be the piston and ring if your lucky Quote Link to comment Share on other sites More sharing options...
vortex666 Posted July 21, 2014 Author Share Posted July 21, 2014 Hmm,will take it apart as soon as i have some time and upload some pictures Sent from my iPhone ? using Tapatalk Quote Link to comment Share on other sites More sharing options...
Nitroholic Posted July 21, 2014 Share Posted July 21, 2014 Definitely stripdown time. Something has gone bang. Could be a number of things...but start with stripping the top end off the motor and having a look. Remove the exhaust first and have a peek inside. If it's gone....you'll see the end result! Clutch and driveline failures can stall a motor....but in the vid, it quit while you were hard on the gas, not under braking.... but before you open up the top...undo the pinion bolt and check your drivetrain. moves freely Quote Link to comment Share on other sites More sharing options...
vortex666 Posted July 23, 2014 Author Share Posted July 23, 2014 [emoji107]i guess its the end... Sent from my iPhone ? using Tapatalk Quote Link to comment Share on other sites More sharing options...
Feedtheinferno Posted July 23, 2014 Share Posted July 23, 2014 Na super-glue will sort that....and a hammer. Quote Link to comment Share on other sites More sharing options...
mini-z-awd Posted July 23, 2014 Share Posted July 23, 2014 holy poop that`s going be expensive to fix Quote Link to comment Share on other sites More sharing options...
kangarilla Posted July 23, 2014 Share Posted July 23, 2014 did you put nitro glycerine in it instead of 2 stroke ? Quote Link to comment Share on other sites More sharing options...
walters Posted July 23, 2014 Share Posted July 23, 2014 I know it don't help but I might be wrong but looks like the pin thing that keep the piston on as come off Quote Link to comment Share on other sites More sharing options...
Nitroholic Posted July 23, 2014 Share Posted July 23, 2014 The crankcases are probably fine, and if the debris stayed out of the way....the bearings and oil seals should be ok. As a minimum though, you would be needing a new crank/rod, new piston and head. Might be a good opportunity to pick up a new 4 bolt motor.... like the CY F270 or a Zenoah 29 I have the 27.5 CY 4 bolt, and it's a great motor for the price. Quote Link to comment Share on other sites More sharing options...
kangarilla Posted July 23, 2014 Share Posted July 23, 2014 i'll second the cy 27.5 4 bolt, very nice mmmmmmmmm Quote Link to comment Share on other sites More sharing options...
vortex666 Posted July 23, 2014 Author Share Posted July 23, 2014 Not worth fixing,will have to buy a new engine..crankcases are fine,just like nitroholic said,needs new crank/rod piston and head..anyway,i was just wondering what the hell happened...was the engine too hot??not getting enough air due to the mesh mod??cant really figure it out.. Sent from my iPhone ? using Tapatalk Quote Link to comment Share on other sites More sharing options...
mini-z-awd Posted July 23, 2014 Share Posted July 23, 2014 Not worth fixing,will have to buy a new engine..crankcases are fine,just like nitroholic said,needs new crank/rod piston and head..anyway,i was just wondering what the hell happened...was the engine too hot??not getting enough air due to the mesh mod??cant really figure it out.. Sent from my iPhone ? using Tapatalk Not worth fixing,will have to buy a new engine..crankcases are fine,just like nitroholic said,needs new crank/rod piston and head..anyway,i was just wondering what the hell happened...was the engine too hot??not getting enough air due to the mesh mod??cant really figure it out.. Sent from my iPhone ? using Tapatalk if its the stock km motoro then it would happen anytime as there not made to the same tolerances or metal as cy or zen motors i guess that`s why there cheap to buy in the first place Quote Link to comment Share on other sites More sharing options...
vortex666 Posted July 23, 2014 Author Share Posted July 23, 2014 Yeah,its the stock km30.5cc,had about 30 tanks on it.. Sent from my iPhone ? using Tapatalk Quote Link to comment Share on other sites More sharing options...
marder Posted July 24, 2014 Share Posted July 24, 2014 Might be a good opportunity to pick up a new 4 bolt motor.... like the CY F270 I have the 27.5 CY 4 bolt, and it's a great motor for the price. You trying too make out yours is bigger than it is Lol, thought 27.2 But yeah heard great things bout F270's, just put one in shorty I building Quote Link to comment Share on other sites More sharing options...
Nitroholic Posted July 24, 2014 Share Posted July 24, 2014 27.2478cc if we stick to 4 decimals for Pi But for the money, it seems to push out a decent balance of power and torque. Better built than a KM engine by a country mile. Quote Link to comment Share on other sites More sharing options...
vortex666 Posted July 26, 2014 Author Share Posted July 26, 2014 Right lads,obr 5.5hp pro stock 30.5cc long block on the way,will it be fine with my old walbro wt997 or is it essencial to get a wt990??thanks lads Sent from my iPhone ? using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Nitroholic Posted July 26, 2014 Share Posted July 26, 2014 Best person to ask would be your engine supplier... I would think the 990 would flow slightly better, you'll just need to learn to start without a choke Quote Link to comment Share on other sites More sharing options...
