poor distance from my cars
seanSOUTHEND
hi all i have x2 1/8 nitro buggy's . 1 is a neo not sure on other ,any way i noticed there losing signal only after a few meters unlike my mta4 i used to have would go few football size fields with no issue. i have tried new hump packs in car and really gd rechargable bats in my controller
any idea how i can make this better ?
Silly question time ...
Tx batteries OK?
Car OK?
When charge runs low, then distance is one of the first things affected.
Are you running near any remote open / close doors?
Al.
Tx batteries OK?
Car OK?
Al.
hi i have charged the bats in controller fully . and the hump pack is on charge full amount. my mta4 used all the same bats and had no issue .
its so weird this is in a open area .. field
Shouldn't happen.
Must be a broken wire somewhere - antenna on Rx perhaps?
Either that or you're running above an iron ore deposit!
It is strange. I'm going for a broken / loose wire.
Can you try re-binding? Perhaps ....
Al.
Shouldn't happen.
Al.
its doin it on both cars . as i run them in the same area i used to take the mta4 which had no issues .. id be lucky for them to go as far as half a pitch over the field
If its the same Tx, is the Antenna connected?
Don't know the radio and 2.4G.Hz don't really have antenna's like the good 'ol 27 M.Hz did ...
Something's odd.
Look for 'common denominator' ...
Al.
Something's odd.
Al.
how do i know if i have a built in fail safe . as i have another external fail safe also ?
I suppose you could:
  1. Remove the external failsafe.
  2. Find instructions / download if necessary for the radio set you have.
  3. Reset the failsafe as per instructions - yes, many are built in.
  4. Test it works without firing up.
  5. Now, test it out.
Never know, might work.
Good luck.
Al.
