Lee_m Posted April 15, 2014 Share Posted April 15, 2014 (edited) Hi peeps I'm sure this has been done but i could not find much about it, I bought a full set on Hostile Dogbone Boots from MMR Largescale The reason i changed the boots is because they had split 'well one had anyway' lol So, thought i would take some pictures with the iphone 'other phones available' as i was doing the second drive shaft If this is c@ap and not needed on the forum just remove it lol So, one drive shaft end, need to remove the pin as the new boot will not fit over the end This was my idea on how to remove the pin and its in there REALLY WELL Small socket on one side and using the vice apply pressure to it and the pin with move Pin has moved then youll need somthing small to push the pin out the rest of the way i used a small torx bit Pin nicely removed WD40 inside the new boot Push the new boot onto the drive shaft Thats one side done now onto trying to get the other side on Push the small end of the boot inside, 'like in the picture' Its really hard to push on but keep working at it Now pull the boot the right was around Need to get the pin back in now so just do it in reverse but without the torx bit all done BEER TIME Edited April 15, 2014 by Lee_m 1 Quote Link to comment Share on other sites More sharing options...
Thunderwolf Posted April 15, 2014 Share Posted April 15, 2014 good guide....not much help if (like me) you don't have a vice to hand. 1 Quote Link to comment Share on other sites More sharing options...
Noj Posted April 15, 2014 Share Posted April 15, 2014 Viceless also, however, the hostile boot tool comes in very handy Good guide tho Quote Link to comment Share on other sites More sharing options...
Jim-Bob Posted April 15, 2014 Share Posted April 15, 2014 Good guide mate, nice clear pictures and easy to follow steps! 1 Quote Link to comment Share on other sites More sharing options...
(-:AD:-) Posted April 15, 2014 Share Posted April 15, 2014 Good guide, how I did it when I had pins, got the ball drive now though. A sticky? Quote Link to comment Share on other sites More sharing options...
CuttyBadmanz Posted May 23, 2014 Share Posted May 23, 2014 Use a grommet expanding tool, it a three pronged thing that opens out to about 25mm I'll post a link. Quote Link to comment Share on other sites More sharing options...
RCbutcher Posted October 25, 2014 Share Posted October 25, 2014 I just put some on my fg just by pulling them over, out of 4 only one split slightly but ther cheap boots from ebay $4 for six i think. Im glad I've seen this tho so when the pins wear down can you just buy new pins or mayb find something else to wedge in. Titanium rod or something. Quote Link to comment Share on other sites More sharing options...
