Noj Posted November 28, 2013 Share Posted November 28, 2013 Yup, be a shame to have the new kit suffer damage for the sake of a pair of connectors, really. You may as well just drop the kit in a pan of boiling oil, the effect will be similar... The ec3 will be sufficient, aren't expensive, and as noted, are very easy to solder (cos they are bullets, which then push into the plastic casing). Quote Link to comment Share on other sites More sharing options...
billyupnorf Posted November 28, 2013 Author Share Posted November 28, 2013 if I change the connector on he car does that mean I would need to cut the battery connector and solder a new on that too? What kind of connectors would recommend that's easy to change and not too much on cost. I was looking at this battery here http://www.modelsport.co.uk/orion-sport-power-pack-4500-7.2v-/rc-car-products/37587My thinking was it's same connector as the current charger so no need for a new charger, but this battery has a higher mah as my current one is 2000mah Quote Link to comment Share on other sites More sharing options...
Bonez Posted November 28, 2013 Share Posted November 28, 2013 if you change one connector you will have to change the lot mate. so car, battery(s) charger and as said before look for the losi EC3, hobbyking sell them in bags of 10 male and 10 female for a few quid they are the same to solder as the bullets you have just soldered onto your motor wires so easy peasy i use those battery's myself so i recommend them Quote Link to comment Share on other sites More sharing options...
billyupnorf Posted November 28, 2013 Author Share Posted November 28, 2013 if you change one connector you will have to change the lot mate. so car, battery(s) charger and as said before look for the losi EC3, hobbyking sell them in bags of 10 male and 10 female for a few quid they are the same to solder as the bullets you have just soldered onto your motor wires so easy peasy i use those battery's myself so i recommend them Would you have a link by any chance? I just googled some and they do look fairly straight forward replacement Quote Link to comment Share on other sites More sharing options...
Bonez Posted November 28, 2013 Share Posted November 28, 2013 look at hobbyking.com mate http://www.hobbyking.com/hobbyking/store/__41513__EC3_plugs_10pairs_set_UK_Warehouse_.html Quote Link to comment Share on other sites More sharing options...
BigBadJFly Posted November 28, 2013 Share Posted November 28, 2013 (edited) if I change the connector on he car does that mean I would need to cut the battery connector and solder a new on that too? What kind of connectors would recommend that's easy to change and not too much on cost. I was looking at this battery here http://www.modelsport.co.uk/orion-sport-power-pack-4500-7.2v-/rc-car-products/37587 My thinking was it's same connector as the current charger so no need for a new charger, but this battery has a higher mah as my current one is 2000mah You could just get an adaptor wire for the charger rather than cutting off and soldering on new one Link Here EDIT: oops, just noticed that they are out of stock, may as well just solder on new ones Edited November 28, 2013 by BigBadJFly Quote Link to comment Share on other sites More sharing options...
andy1980 Posted November 28, 2013 Share Posted November 28, 2013 Are the Yeahracing conversion kits worth buying as its a complete hop up kit have just looked on line and there coming in at Quote Link to comment Share on other sites More sharing options...
billyupnorf Posted November 29, 2013 Author Share Posted November 29, 2013 The cheapest I have seen the full kit for is Quote Link to comment Share on other sites More sharing options...
andy1980 Posted November 29, 2013 Share Posted November 29, 2013 It was on a american site for $149 and with exchange rate it come in st 94 quid and came in 4 colours red,blue,orange and pink Quote Link to comment Share on other sites More sharing options...
billyupnorf Posted November 29, 2013 Author Share Posted November 29, 2013 I only got the essentials as recommended above, thou I think I have the wrong steering parts as they fit but are very loose compared to the stock parts, anyone else had this problem? Quote Link to comment Share on other sites More sharing options...
whitecomet Posted November 29, 2013 Share Posted November 29, 2013 great post.. just bought a TT01E and looking to raise its speed a little so hopefully things in here can help Quote Link to comment Share on other sites More sharing options...
andy1980 Posted November 29, 2013 Share Posted November 29, 2013 I looked at the same set up but it looks different to mine i have a long bottom bar thats the same but the other two i only have one that is long and other is only half the size Quote Link to comment Share on other sites More sharing options...
billyupnorf Posted November 29, 2013 Author Share Posted November 29, 2013 I managed to figure out the flimsiness, I was using the stock poles instead of screwing them in. It's good upgrade and turning feels more responsive Quote Link to comment Share on other sites More sharing options...
NuttyProfessor Posted November 29, 2013 Share Posted November 29, 2013 Thats why I got rid of the poles and went back to the standard TT01 steering instead of the E. Quote Link to comment Share on other sites More sharing options...
billyupnorf Posted November 29, 2013 Author Share Posted November 29, 2013 It seems to be ok now the steering parts. I have just ordered the hpi battery, this has 4300mah so I am assuming I'll get more play time as currently only getting 20-25minshttp://www.modelsport.co.uk/hpi-plazma-7.2v-4300mah-nimh-stick-pack-re-chargeable-battery/rc-car-products/38774 Quote Link to comment Share on other sites More sharing options...
NuttyProfessor Posted November 30, 2013 Share Posted November 30, 2013 Id still go lipo to be honest, get a hardcase racing pack from hobbyking, 5000mah will give you upto 35-40 mins. You will have to trim the fins in the battery tray to fit a square pack but its worth it to get the extra punch and runtime Quote Link to comment Share on other sites More sharing options...
