Phantom range ?
  • Please log in to reply
14 replies to this topic
#1 S40bul
S40bul
    MSUK Regular
  • Members
  • PipPipPipPipPip
  • 311 posts
  • RC Cars:Losi 8ight 2.0T,Ansman vapour , LOSI 5ive Losi mini 8ight. Heliguy viper quadcopter, DJI Phantom , DJI F550
Posted 12 June 2013 - 10:27 PM
Been pushing the range a bit on the phantom lately (FPV) , seem to be getting well over the recomended 300m mark ok on stock set up
http://m.youtube.com...h?v=7CZytDzD6AA
http://m.youtube.com...h?v=FK2yVaXsK7o
  • richarddenton1982 likes this
#2 hebby
hebby
    Jony Nitro has sugar puff teeth.
  • Members
  • PipPipPipPipPipPipPipPipPipPipPipPipPipPip
  • 5,889 posts
  • RC Cars:HPI Apache C1 Flux & DJI Phantom 2 Vision+ V3
Posted 12 June 2013 - 10:58 PM
Must admit I've had a fair distance with mine :-) but now I got the 600mw transmitter so should double it easy :-) heard its over a mile range :-0
#3 S40bul
S40bul
    MSUK Regular
  • Members
  • PipPipPipPipPip
  • 311 posts
Posted 13 June 2013 - 08:38 AM
Nice , was thinking of upgrading Tx /Rx to futaba. I've watched a couple of YouTube vids which makes the task look a bit less daunting ....... What you running with ??
Planning an OSD when back in stock , then can keep a closer eye on the battery level ect. Never really pushed it by the 8 minute mark
#4 hebby
hebby
  • Members
  • 5,889 posts
Posted 13 June 2013 - 05:57 PM
Got one running stock and one running a DX6I
Only use mine with Fatshark and Gopro but currently awaiting on a GPS unit off a mate of mine  :thumbsup:
When i use my FPV i use my iphone as a timer of around 7 mins then i know i got at least 2 mins to get back  :yes:
  • S40bul likes this
#5 Tamiyacowboy
Tamiyacowboy
    MSUK Addict
  • Members
  • 6,065 posts
  • RC Cars:canon 350D
Posted 13 June 2013 - 06:48 PM
FPV range you can push way beyond a mile and a half, BUT
the problem lays with your antennas , them rubber duck antenna are useless.
so first off you need a decent cloverleaf thats correct for your TX,
next is your RX or whats call the ground base, your going to need a Patch antenna.
this is like a flat panel and gives out a small cone beam, fly out of this beam you loose signal.
now with the above method your focusing the beam alot more and this means a longer range ability, but
at a cost to a smaller cone beam size and the constant moving of patch antenna to have best focus of beam onto target.
#6 S40bul
S40bul
    MSUK Regular
  • Members
  • PipPipPipPipPip
  • 311 posts
Posted 13 June 2013 - 10:12 PM
It all gets a bit 'James Bond like' Tamiya ....
I take it the cloverleaf / patch antenna set up is for flying the thing and not for the video link ??
Got a couple of spironet antennas for the video tx / rx which made a huge difference
#7 Tamiyacowboy
Tamiyacowboy
    MSUK Addict
  • Members
  • 6,065 posts
Posted 14 June 2013 - 10:25 AM
nope for the vid link buddy, you keep a planner cloverleaf on the quad side.
at the ground base your antenna changes to a patch antenna. it goes from the clover leaf design to a flat panel
what its doing is focusing the beam to a narrow angle, and adds that extra range, the beams angle is less
but range becomes more.
check the video below at Ali's backpack antenna, notice its a flat panel not a clover.
then look if he shows his aircraft, notice they carry the cloverleaf.
what this does is turns you into an antenna tracker
#8 S40bul
S40bul
    MSUK Regular
  • Members
  • PipPipPipPipPip
  • 311 posts
Posted 14 June 2013 - 11:36 AM
Ahh nice Tamiya, got you now. Cheers
Take it the OSD has a signal strength showing so you can turn to keep the patch antenna pointing in right direction
#9 Tamiyacowboy
Tamiyacowboy
    MSUK Addict
  • Members
  • 6,065 posts
Posted 14 June 2013 - 12:31 PM
yes osd overlays data.
your able to set them up and choose what you want shown on the screen layover.
alt - speed - airspeed - gps signal - voltage - amp draw etc etc.
if say everything goes to pot, you loose the vid feed like a good 1/4 mile out.
you scan body to try get the cone beam  but cant, ( this happens in a few seconds )
you will auto start to search a signal, banking craft either left or right and back towards home.
if not you slam the get out of jail switch ( RTH ) , and wait for craft to come back, at same time keeping eye
on goggles/lcd for the signal return from vid
Edited by Tamiyacowboy, 14 June 2013 - 12:34 PM.
  • S40bul likes this
#10 S40bul
S40bul
    MSUK Regular
  • Members
  • PipPipPipPipPip
  • 311 posts
Posted 17 June 2013 - 04:51 PM
Well ...... Had the phantom failsafe kick in yesterday. Was FPV'n along a cliff edge when I must have dropped below line of sight behind a tree. Lost video link and Tx control ... Wooops !
http://m.youtube.com...h?v=rsEZDzH56D4
The phantom stopped in its tracks , flew vertical then started its return to home ...... Where I regained control before it landed
What a bit of kit !
#11 hebby
hebby
  • Members
  • 5,889 posts
Posted 17 June 2013 - 09:17 PM
Yeah they have a new feature when the sticks are not moved for 20 seconds OR the phantom recognises no movement from sticks for 20 seconds fail safe kicks in :-)
Never needed it or needed to hit fail safe but have tested ;-) and can say mine also works a treat :-)
#12 Tamiyacowboy
Tamiyacowboy
    MSUK Addict
  • Members
  • 6,065 posts
Posted 18 June 2013 - 11:16 AM
here you go S40bul, i adjusted link to direct play .
yep handy is that rth, i did notice your on the hill top nearly and the craft was getting below the
surface horizon.
#13 S40bul
S40bul
    MSUK Regular
  • Members
  • PipPipPipPipPip
  • 311 posts
Posted 18 June 2013 - 06:28 PM
[quote
surface horizon.[/quote]
Ah nice one bud, wondered how the youtube links I post show differently
#14 S40bul
S40bul
    MSUK Regular
  • Members
  • PipPipPipPipPip
  • 311 posts
Posted 19 June 2013 - 08:16 PM
New transmitter arrived today , hopefully will get it hooked up to the Phantom soon ........ And hopefully without any glitches
Should be a tad better for range
#15 S40bul
S40bul
    MSUK Regular
  • Members
  • PipPipPipPipPip
  • 311 posts
Posted 01 July 2013 - 06:01 PM
Finally got round to hooking up the Futaba T8J to the Phantom (Was stretching the range a bit at 400m with the stock set up) Had a wee range check today of the T8J and was still getting good signal at over 1km distance .... Well happy
