cutting42 Posted February 27, 2013 Share Posted February 27, 2013 I appreciate there have been a couple of threads on here but thought \I would post my fix to my sons TX. Once I took it apart I figured that the easiest way was to switch the battery supply and I wanted to fit a decent sized switch and put it where it cant easily be knocked on or off. I just soldered together the contacts to permanently keep switched on - sorry for the camera shake I then fitted a toggle switch from Farnell to the main body but out of the way Wired up internally to the positive wire from the battery by cutting the red wire and inserting the switch into the circuit All done and lovely, the only downside to this mod is that you need to make sure the switch is on when you are charging via the usb port DAMHIKT Quote Link to comment Share on other sites More sharing options...
fatboyneil Posted February 27, 2013 Share Posted February 27, 2013 I thought of doing this sort of mod but keeping it all in the wheel housing made more sence as it doesn't interfere with any of its features its a shame flysky did what they did to fix it cause they haven't really fixed the power switch they've just taken away the pcb board that pushes on the spring board thinking that's what the problem was and bad news is its not so all these so called fixed gt3c handsets will eventually get the fault might take a couple of months use bit they will fail Quote Link to comment Share on other sites More sharing options...
cutting42 Posted February 28, 2013 Author Share Posted February 28, 2013 I thought of doing this sort of mod but keeping it all in the wheel housing made more sence as it doesn't interfere with any of its features its a shame flysky did what they did to fix it cause they haven't really fixed the power switch they've just taken away the pcb board that pushes on the spring board thinking that's what the problem was and bad news is its not so all these so called fixed gt3c handsets will eventually get the fault might take a couple of months use bit they will fail Yeah your solution is neater but I did not have a low profile switch and I have the toggle in my spares box. I had a couple of goes at fixing the wires but they always failed eventually and always at an inconvenient time. Quote Link to comment Share on other sites More sharing options...
