snapon Posted January 5, 2013 Share Posted January 5, 2013 Whilst setting up my throttle linkage on car today and setting noo on the transmitter i then noticed that whilst held in my hand any slight movement of the transmitter and the steering servo is twitching ? Hold the transmitter still and tap the base where batterys are and steering servo keeps twitching ? Thinking about it now i always wondered why when i switched on trans then car and done throttle and steering check , everytime i put trans down on ground the servo tried moving ? I take it this shouldnt happen as also when you hold it in your hand and move it around u get the twitching still ! Think these km ones are copies of the real flysky ones and im gonna ring rcmodelz on monday for a replacement under warranty Quote Link to comment Share on other sites More sharing options...
walters Posted January 5, 2013 Share Posted January 5, 2013 you will find all flyskys r the same mate might be a rx Quote Link to comment Share on other sites More sharing options...
snapon Posted January 5, 2013 Author Share Posted January 5, 2013 Might be a rx ? Quote Link to comment Share on other sites More sharing options...
Scoobie007 Posted January 5, 2013 Share Posted January 5, 2013 Tx = transmitter rx = receiver I think! ;-) Quote Link to comment Share on other sites More sharing options...
walters Posted January 5, 2013 Share Posted January 5, 2013 Swop or servo a round and try it again Quote Link to comment Share on other sites More sharing options...
snapon Posted January 5, 2013 Author Share Posted January 5, 2013 Surely its gotta be a tx fault cos you tap it or move it and servo twitches and makes noise . If u keep it still its fine Quote Link to comment Share on other sites More sharing options...
(-:AD:-) Posted January 5, 2013 Share Posted January 5, 2013 Buy a new rx. Only a couple of quid Quote Link to comment Share on other sites More sharing options...
snapon Posted January 6, 2013 Author Share Posted January 6, 2013 Just trying to understand why it would be an rx fault before i replace it ? Quote Link to comment Share on other sites More sharing options...
walters Posted January 6, 2013 Share Posted January 6, 2013 none of your wires are trapped try to rebind it mate Quote Link to comment Share on other sites More sharing options...
goldman Posted January 6, 2013 Share Posted January 6, 2013 Hi could it be a bad battery conection in the TX. Goldman Quote Link to comment Share on other sites More sharing options...
snapon Posted January 9, 2013 Author Share Posted January 9, 2013 Tried swapping servos around on rx and still same , just this time throttle servo twitching . All connections in rx good and no trapped wires . Spoke to rcmodelz and was told to send tx snd rx back for them to check out but to be honest i so peeded off with keep doing this . Had the same with steering servo . Think im gonna drive the km of beachy head but oh hang on a minute it doesnt bloody start YET AGAIN !!!! knew i should of saved up for an hpi lol Quote Link to comment Share on other sites More sharing options...
Jolly_roger_uk Posted January 9, 2013 Share Posted January 9, 2013 From the sounds of it you have a dodgy steering potentiometer in the transmitter. Sometimes a 'pot' can go 'dirty' and get affected by vibration. Had a similar issue some time ago with an old futaba set. Luckily the pots were open frame, and a dash of contact cleaner sorted it. Quote Link to comment Share on other sites More sharing options...
snapon Posted January 9, 2013 Author Share Posted January 9, 2013 Is it worth me opening it up to take a look before i send it back and strip car again to get rx out aswell Quote Link to comment Share on other sites More sharing options...
Nitroholic Posted January 9, 2013 Share Posted January 9, 2013 No....really not worth it. You open up the TX at your own risk....as they may then claim you have tampered with it. Better to send it back as is. They will probably just send you a replacement radio and deal with the faulty one later through whoever their supplier is. These are cheap radios, so don;t expect great things on quality control. You will get the occasional rogue one. Just be glad you didn't buy it from an E-Bay seller in China! at least it's easy to send back Quote Link to comment Share on other sites More sharing options...
snapon Posted January 9, 2013 Author Share Posted January 9, 2013 Thanks will wrap it up tonight and send it back ! Quote Link to comment Share on other sites More sharing options...
snapon Posted January 11, 2013 Author Share Posted January 11, 2013 Replacement tx on its way back to me Quote Link to comment Share on other sites More sharing options...
walters Posted January 11, 2013 Share Posted January 11, 2013 good Quote Link to comment Share on other sites More sharing options...
snapon Posted January 12, 2013 Author Share Posted January 12, 2013 Recieved brand new flysky gt3b tx and rx this morning , fitted and all good ! Feels a bit better quality then the other one which km stickers instead of flysky but i guess km just use there own stickers on the flysky set ? Quote Link to comment Share on other sites More sharing options...
babylon Posted January 12, 2013 Share Posted January 12, 2013 Radios can be funny, I remember when I got my ERevo and took out the Traxxas radio to flogon, When I put my gt3b in I found that the Traxxas servos for some reason wouldn't work with any of the 5 rx's I had, And that was with an external BEC, Had to change the servo's in the end, Weird. Quote Link to comment Share on other sites More sharing options...
