RCM Lipos, Any Good?
Started by
justgreatsam
, Feb 04 2012 05:56 PM
16 replies to this topic
#1
Posted 04 February 2012 - 05:56 PM
So far i have been looking at:
6000KV Motor
OR (Dont know which to choose for a 2WD off-road mad monkey)
4000KV Motor
60A ESC
AND
3S RCM
2S RCM
2S GensAce
Im not bothered about the softcase/hardcase situation, what i want to know is which motor to choose and which battery to go with it, i will be using an IMAX B6 charger.
6000KV Motor
4000KV Motor
60A ESC
AND
3S RCM
2S RCM
2S GensAce
#2
Posted 04 February 2012 - 05:58 PM
i'd go for the 4000kv it would be a bit mental with a 6000kv!!
#4
Posted 04 February 2012 - 06:13 PM
My son has the 2s RCM lipo in his slash 4X4, ran it for last 6mths with no problems.
#6
Posted 04 February 2012 - 06:16 PM
got 2s rcm"s in my firestorm thanks to autobutcher"s recommendation , again no probs so far
#8
Posted 04 February 2012 - 06:20 PM
Quote
4000KV it is, what gearing would you suggest? (Current Pinion/Spur is 21T/86T)
#11
Posted 04 February 2012 - 06:52 PM
a brushless motor will have more power so about 4+ more teeth but it will depend on the temps of the motor. if if gets hot it will need more teeth. a 4000kv motor on 2s will do just under 30,000 and so if you run it on your current pin and spur it will be slower
#12
Posted 04 February 2012 - 07:29 PM
wouldnt i need less teeth on the pinion if it gets too hot?
#13
Posted 04 February 2012 - 07:33 PM
normally it's going too fast or over revving which means it needs more teeth
#14
Posted 04 February 2012 - 07:51 PM
I'v just got the gensace 3s 3000mah lipo and its great, came with a perfect balance and I have had 2 cycles with it and its superb
the others have good reviews on that website also
