i think i've killed my exhaust gaskets please help
Started by
norcoforever
, Feb 02 2012 04:01 PM
9 replies to this topic
#1
Posted 02 February 2012 - 04:01 PM
hi all i think i've killed my exhaust gaskets, last time i ran the baja the exhaust came a little loose so i cranked up the gasket bolts however just above the exhaust when idling there is a lot of cold air also a fair bit of oil came out. ilve made a video to show where the air/oil is and to show how it sounds on idle can anyone confirm A if i need new ones and B can someone recommend some replacements
any help appreciated as i need to order new ones asap to hopefully run saturday
#2
Posted 02 February 2012 - 04:06 PM
would these work? http://www.freeprawn...sket-fd225.html and how quick are freepawn on delivery
#3
Posted 02 February 2012 - 06:04 PM
Cann't go wrong with a copper gasket.....
#4
Posted 03 February 2012 - 07:25 AM
As above a copper gasket is needed but 2, as you have a x port between the head and
exhaust.
Also get some of thing too
http://www.ebay.co.u...=item20ba5cc913
How to fit with sealent and gaskets
Head
Sealent
Gasket
Sealent
X port
Sealent
Gasket
Sealent
Exhaust
I know it sound silly having all that, but it WILL stop the exhaust leaking
Gav
exhaust.
Head
Sealent
Gasket
Sealent
X port
Sealent
Gasket
Sealent
Exhaust
Gav
#5
Posted 03 February 2012 - 07:37 AM
I used to use paper gaskets bit of sealer job done...
Sent from my GT-I9100 using Tapatalk
#6
Posted 03 February 2012 - 08:22 AM
The cold air will be draft from flywheel
#8
Posted 03 February 2012 - 10:42 PM
another thing that might help is normal hex bolts for header aint the best, i use studs with spring washers & 2x nuts & also use stud lock for the studs. Solid & my pipe never comes loose or leaks
#9
Posted 03 February 2012 - 11:48 PM
Good point! Why have I never heard this on an RC forum before?
On every other manifold I have worked on (no matter what the engine) they have used studs, so why not on 1/5th engines? Heck, they are easy to make too.
#10
Posted 04 February 2012 - 12:29 AM
