http://www.modelspor...products/367264
FTX Punisher plus
#1
Posted 02 February 2012 - 02:12 PM
#2
Posted 02 February 2012 - 02:27 PM
Hope you enjoy you new rc.
#3
Posted 02 February 2012 - 04:46 PM
#4
Posted 02 February 2012 - 05:49 PM
#5
Posted 02 February 2012 - 05:53 PM
#6
Posted 02 February 2012 - 08:48 PM
#7
Posted 02 February 2012 - 09:19 PM
Baja 5b, on 02 February 2012 - 05:53 PM, said:
no the ftx use a 2 blt engine
ive got the destroyer good bit kit but it is bloody heavy. the alloy and baja wheels dont help mine tho
Edited by howie87, 02 February 2012 - 09:21 PM.
#8
Posted 02 February 2012 - 09:28 PM
http://www.cmldistri...us Addendum.pdf
Like the old Smartech ?
Not a good move if that's right ?
#9
Posted 02 February 2012 - 09:33 PM
toys4x4boys, on 02 February 2012 - 09:28 PM, said:
http://www.cmldistri...%20Addendum.pdf
ah got to be honest didnt look just going off the old one.
heard those engines were terrible
#10
Posted 02 February 2012 - 09:42 PM
So far ive fitted:
Center diff locker to reduce front wheel spin.
ZMC Alloy center diff mounts as the plastic one flex under load.
Alloy rear diff & gearing.
ZMC alloy diff case, as the plastic one flexes under load.
ZMC alloy engine mounts.
ZMC clutch carrier plate.
ZMC C Hubs. then modded them as the soon suffered wear and got floppy.
ZMC threaded shocks
ZMC CVD drive shafts all round, as they are better than the dogbones.
HPI wheel converters, as I got fed up with the wheel nut coming loose.
and the Stock servos are not that great, so they have been changed for decent servos.
I have also played around with the plug in out drive cups as the stock sliding ones tend to get jammed and don't slide in & out as they should, but the plug ins can pop out and get lost when you throw a drive shaft, so went back to the stock ones.
The ZMC alloy parts seem to be better quality than the FXT parts and cheeper, so well worth going for.
but its basically a good buggy.
Or at least the 28cc engine would be a good choice of engine if it was a Zen or even a CY. that 3 bolt one will have to prove its self!
Edited by Spriggan, 02 February 2012 - 09:45 PM.
#11
Posted 02 February 2012 - 10:22 PM
#12
Posted 03 February 2012 - 06:05 AM
#13
Posted 03 February 2012 - 06:25 AM
And he gets then from CML who's spec shown above.
#14
Posted 03 February 2012 - 07:09 AM
Gav
#15
Posted 03 February 2012 - 03:42 PM
No really i have one its a 3-bolt.....
Nah i recon the exhaust will have to go first.... The engine not bad tbh.
Edited by Baja 5b, 03 February 2012 - 03:45 PM.
