Carson Rock Warrior
  • Please log in to reply
No replies to this topic
#1 Garry
Garry
    Racers do it 5mins at a time!
  • Forum Staff
  • 21,655 posts
  • Gender:Male
Posted 02 February 2012 - 01:26 PM
Quote
Posted Image
With the Rock Warrior CARSON presents an all-wheel truggy, which is technically similar to the top-seller Dirt Warrior.  The Rock Warrior is built ready to ride complete with drive battery including charger and transmitter batteries and therefore 100% RTR.
Posted Image
Features
  • X10ET chassis with central shaft
  • All-wheel drive (4WD)
  • Fully ball bearing mounted
  • Aluminium motor mount
  • 12 mm aluminum driver, hex
  • Heavy duty adjustable aluminum oil filled shocks (knurled nut)
  • High Grip Wheels Race-bonded
  • Stabilizer, front / rear
  • Fall h v / adjustable
  • Adjustable front track
  • central aluminum main shaft
  • Hexagon socket set screws
  • complete set ready to ride
  • 2-channel radio control system Reflex Pro 2.4 GHz with dual rate (throttle, steering)
  • Electric motor CARSON Cup Machine
  • Speed ??control knob with aluminum heat sink and the receiver has a fail safe function
  • Printed body with decals
  • NiMH drive battery 7.2 mAh V/1900 with TAMIYA plug
  • Turbo charger with 900 mA charging current 6
Posted Image
Specifications
  • Length 410 mm
  • Width 235 mm
  • Height 155 mm
  • 270 mm Wheelbase
  • Ground clearance 35 mm
  • 12 mm hex hub
  • Weight about 1450 g
Source: RCNews.de
Modelsport UK
