Engine heater required?
  • Please log in to reply
68 replies to this topic
#1 Wattser
Wattser
    Getting Started
  • MSUK Supporter
  • PipPip
  • 91 posts
  • Gender:Male
  • RC Cars:Losi 8ight
Posted 28 January 2012 - 05:22 PM
It it advisable to purchase a 12v hair dryer or engine heater? I want to break my Losi in but I do not posses a hair dryer or heater. Can i break it in without heating?
Thanks
#2 norcoforever
norcoforever
    Veteran Member
  • MSUK Supporter
  • PipPipPipPipPipPipPipPipPipPipPip
  • 3,264 posts
  • Gender:Male
  • RC Cars:firestorm flux, baja 5bss
Posted 28 January 2012 - 05:26 PM
it'll be a lot harder without as the engine are very tight i would advise picking up a hairdryer =]
#3 Ziggy122
Ziggy122
    Loving Italian Style!
  • MSUK Supporter
  • PipPipPipPipPipPipPipPipPipPipPipPipPipPipPip
  • 9,810 posts
  • Gender:Male
  • RC Cars:<lightly restored Rush Evo><Hyper 7 tq (.21)><Traxxas Rustler VXL With Lipo><Picco MiniZ Helicopter>
Posted 28 January 2012 - 05:29 PM
Any hairdrier will do :) i use a mini travel one, takes longer but it was free so why not
a 12v car one suck some serious amps, i think it was like 15amps i worked one out at, if thats what your going to use, ensure your 1:1 cig lighter is capable
As for engine heaters - they just a gloryfied tyre warmer, but still will help
the hotter you can get the Engine the easier it becomes
Heat makes liner expand = lowers the overtight pinch = lowers compression = turns over faster = better change of getting the dam thing started....
ziggy
#4 Baja 5b
Baja 5b
    MSUK Regular
  • Members
  • 988 posts
  • Gender:Male
  • RC Cars:see sig!
Posted 28 January 2012 - 05:31 PM
I never use them..... the whole point of a brake in is to allow the piston and sleve to warm up and cool down together. Of cource they do make starting a tad bit easier, but if a nitro engine is tuned correctly then it'll start quickly anyway....
Some dont some do.... there mainly used my racers so there engine are kept hot untill the race starts.
#5 anton
anton
    Getting Started
  • Members
  • PipPipPipPip
  • 165 posts
  • Gender:Male
  • RC Cars:Hyper 7 Black Ed. Losi 8ight 2.0
Posted 28 January 2012 - 05:59 PM
I wouldn't bother with a 12v hair drier.  I would recommend an engine heater though - they make starting an engine much easier.  If you have some diy skills and a pound-shop nearby, you can pick up the parts to make a 12v heater for around £10.  All you need for a basic heater is a stainless steel flask, a 55w car headlight bulb, some high current cable, and some croc-clips (or similar) to attach it to the 12v supply.  You can make a fancier one by adding a 12v fan to push the hot air through the heater and onto the engine (costs about £5 from Maplins).
#6 Wattser
Wattser
    Getting Started
  • MSUK Supporter
  • PipPip
  • 91 posts
  • Gender:Male
Posted 28 January 2012 - 06:20 PM
Thanks guys and Anton I will take your advice I think and make myself a heater. They are at least £80 online and I am not prepared to spend that much. I will speak to the engineers where I work to see if they can advise me on wiring etc.
#7 thevmister
thevmister
    MSUK Regular
  • Members
  • 480 posts
  • Gender:Male
  • RC Cars:xray808, kysho mp9, hotbodies ve8
Posted 28 January 2012 - 06:35 PM
i bought the heater for 80 not justified in my opinion so the bulb is a good idea
#8 Slimeon
Slimeon
    Just Registered
  • Members
  • 15 posts
  • Gender:Male
  • RC Cars:fazer mk2, Hoboa Hyper 7 Black
Posted 30 January 2012 - 08:59 PM
I built my own engine warmer out of a can of peas and a 55w headlight bulb. Takes about 10 mins to get my engine up to 185f.
Posted Image
#9 bowie_no7
bowie_no7
    MSUK Regular
  • Members
  • 554 posts
  • Gender:Male
  • RC Cars:HoBao Hyper 7 Black Edition, XTM Rage, Kyosho Alpha, Hyper 7e
Posted 30 January 2012 - 09:30 PM
Or if your out and about I've seen similar selfade heaters that use a lipo instead of a cig plug
#10 Slimeon
Slimeon
    Just Registered
  • Members
  • 15 posts
  • Gender:Male
Posted 30 January 2012 - 09:36 PM
Yeah i'm gonna patch in some different connections later on. But for round about £6 it works a treat.
#11 GSGA
GSGA
    MSUK Regular
  • Members
  • PipPipPipPipPip
  • 340 posts
  • Gender:Male
  • Location:Either in a field or my workshop fixing something I've just broken - in a field...
  • RC Cars:8+savages,kyosho mp777, hpi rs3/4 + others
Posted 30 January 2012 - 09:44 PM
Posted Image
Nice one.
I need something like that since my bash spot is now a fair way from my van which has an inverter and heat gun in it...
#12 jimmytheone
jimmytheone
    MSUK Regular
  • MSUK Supporter
  • 1,206 posts
  • Gender:Male
  • RC Cars:Sandmaster, Inferno 7.5, Losi Micro Dessert Truck BL x2, AE RC8T Tekno'd, Rustler MMP Combo
Posted 31 January 2012 - 09:26 AM
Done the same but used a 12v halogen bulb, a can of beans and a 3S lipo, works a treat.
And as I only had to buy the bulb is cost me £1.50 for 3 bulbs and about an hour with a dremel and a soldering iron.
As above I leave it for around 10 mins, temps around 160f and it starts straight away.
#13 lazkopat
lazkopat
    MSUK Regular
  • MSUK Supporter
  • 554 posts
  • Gender:Male
Posted 31 January 2012 - 10:52 AM
Those halogens bulbs are good to startup the car in the winter. But if you are breaking in your engine then get a heat gun from homebase. I bought one while ago for £17, it has two temperate outputs; 300c & 550c. Warm up the engine to about 170F that's when the expand occurs.
I'm planning to construct one lIke Jim's after seeing it :D
Output-
Heatgun good for breakin
Bulb good for warmup engine.
Edited by lazkopat, 31 January 2012 - 10:55 AM.
#14 notfast
notfast
    MSUK Regular
  • Members
  • 490 posts
  • Gender:Male
  • RC Cars:E firestorm, hpi hellfire, pink lunchbox and a macnum
Posted 31 January 2012 - 11:31 AM
Posted Image
Good skills!
Does the bulb sit directly on the engine?
#15 kkppww91
kkppww91
    MSUK Regular
  • MSUK Supporter
  • PipPipPipPipPip
  • 265 posts
  • Gender:Male
  • RC Cars:firestorm 10t,savage 25
Posted 31 January 2012 - 12:10 PM
That's a good bit of kit. Wouldn't like to get a burn off that tin though.
Modelsport UK
