Quote
Front Sway Bar Kit
Is your Wraith™ set-up for high speed rock racing, or RECON G6 Challenge style events? Then this is the option part you have been waiting for: the Axial Wraith™ Front Sway Bar Kit. Designed for high speed this system will let you soften up your suspension for jumps, while keeping torque twist and body lean to a minimum during acceleration. A sway bar's main function is to control body roll, yet still allow your shocks to move vertically with the changing terrain. What does all this mean? It means more stability at high speed. A must have upgrade for any would be rock racer.
• CNC machined for precision.
• Black anodized aluminum sway bar arms.
• Each kit includes three different steel sway bars for fine tuning body roll and suspension articulation (soft, medium and firm).
• Laser etched Axial logos.
• All required hardware is included.
• Simple bolt on application.
• Kits available for front and rear separately.
AX30781 Sway Bar Kit Front (Soft, Medium, Firm) $45.00
Rear Sway Bar Kit
Is your Wraith™ set-up for high speed rock racing, or RECON G6 Challenge style events? Then this is the option part you have been waiting for: the Axial Wraith™ Rear Sway Bar Kit. Designed for high speed this system will let you soften up your suspension for jumps, while keeping torque twist and body lean to a minimum during acceleration. A sway bar's main function is to control body roll, yet still allow your shocks to move vertically with the changing terrain. What does all this mean? It means more stability at high speed. A must have upgrade for any would be rock racer.
AX30782 Sway Bar Kit Rear (Soft, Medium, Firm) $45.00
Source: RCCA
