Some questions relevant to this topic! Please LOOK
#1
Posted 24 January 2012 - 09:07 PM
I had many RC cars, drifters, on road, offroad, nitro, electric but now i would like something like the car on the video below. I haven't got a lot to spend like £200 pounds im looking for something around £100. Is there any car that would be suitable and good. I would prefer a brand new one because i like building kits. What are the runtimes on normal 7.2v battery packs?
Thanks for any help!!!
#2
Posted 24 January 2012 - 09:15 PM
#3
but, if you want one of those your going to be looking at between £250-350 for either a kit and rest of bits (electrics, batteries and charger) and a ready to run version.
for your budget, get yourself a maverick scout rock crawler, and make yourself a chassis and scale body and you have a scaler. job done! £125ish, new and rtr.
batteries last ages in these things, when i used to run nimhs, (4500mah orion rocket pack) it would last at least a couple of hours, with lipos, 2x 2650 2s lipos will last me a days running easily.
hope this helps, gaz.
#4
Posted 24 January 2012 - 09:17 PM
beaten to it by gaz lol
Edited by norcoforever, 24 January 2012 - 09:17 PM.
#5
Posted 24 January 2012 - 09:22 PM
#6
Posted 24 January 2012 - 09:25 PM
#7
Posted 24 January 2012 - 09:27 PM
andryk, on 24 January 2012 - 09:22 PM, said:
with a little tinkering you will get any body you like to fit. it will more than likely involve knocking up some body mounts but nothing too extreme.
#8
Posted 24 January 2012 - 09:28 PM
big gaz, on 24 January 2012 - 09:27 PM, said:
#9
Posted 24 January 2012 - 09:32 PM
#10
Posted 24 January 2012 - 09:34 PM
i will consider the scout
#11
Posted 25 January 2012 - 11:55 AM
i can vouch for the scout even in standard trim they do work very well
ive fitted mine with an axial shell as wanted it to look different pretty much any 1/10 crawler shell can be made to fit
so your not really limited to the scout's own shell i also found that the scouts shell was heavier than the copy cheap shell
it now has i can only assume the original is made of thicker lexon
if you look lower down you will see wot i have done to mine to improve it
hth
Simon
