* * * * * 1 votes
Schumacher Mi4CXL 1/10th Competition TC
  • Please log in to reply
6 replies to this topic
#1 Garry
Garry
    Racers do it 5mins at a time!
  • Forum Staff
  • 21,655 posts
  • Gender:Male
Posted 24 January 2012 - 03:04 PM
Quote
Posted Image
Seen at last weekend’s Euro Touring Series Rd2 in Italy, Schumacher have officially launched their new Mi4CXL 1/10th Competition Touring Car. The Mi4CXL is the latest version of the highly successful Schumacher Mi4 touring car range. Now with 2 British national titles, numerous European and World event wins including the ETS Pro Stock Championship, the CXL takes winning to the next level. Schumacher’s World Championship winning design team, with the help of top drivers such as Chris Grainger and Martin Hofer have improved the Mi4CX chassis design, making a car that is faster, yet easier to drive than ever before. Mi4CXL drivers will reduce their lap times and improve their positions in both qualifying and race conditions.
Posted Image
- NEW 2mm Aerospace carbon fibre “Soft Weave” chassis and long top deck with optimised flex. Easier to drive with more traction.
- NEW Extreme lightweight 7075- T6 transmission housings.
- NEW Anti- Roll Bar system, lightweight with a near linear response.
- NEW Bridged layshaft mounting with quick release layshaft design for ease of maintenance.
- NEW CNC alloy, 20 tooth layshaft pulley.
- NEW Steering geometry incorporating centre point steering with forward facing balls to fine tune geometry. Fully adjustable Velocity Ratio, Ackermann Angle and Ackerman Rate.
- NEW Stiff 3mm rear shock tower with more shock mounting positions.
- NEW Carbon Fibre wishbones with moulded Roll Bar Ball, for increased traction, lighter weight and better impact absorption.
Posted Image
Posted Image
- Clamp motor mount to adjust side to side weight distribution. The car can be perfectly balanced with different lipo batteries and radio gear.
- Split rear transmission housing.
- Carbon fibre upper link design with options to adjust roll centres.
- Anti roll bar mounts with precise vernier adjustment to minimise play.
- Purple Alloy CNC ‘O’ ring retained wheel hexes.
- Lightweight moulded pivot blocks. Optional twin pivot block system allows infinite adjustment of roll centres, toe- in, anti- squat, and track width on front and rear.
- Fully adjustable, suspension geometry, wheelbase, caster, camber, roll centre, track width, ackerman, droop, front toe in/out, ride height. Anti dive, anti squat can be changed with Speed Secret parts.
- Efficient transmission with twin Kevlar belts and precision CNC pulleys.
- Alloy eccentric adjusters for optimum belt tension. Easy diff height adjustment to allow changes in drive shaft plunge. This can be used to increase or decrease traction.
- Symmetrical chassis layout with few screws minimises tweak.
- Ultra smooth Nickel- Teflon plated threaded alloy shock absorbers for extreme smoothness and durability.
- Lightweight machined diff pulley, Ceramic diff balls, aerospace thrust bearing.
- Narrow efficient thin back belts.
- Ultra lightweight front spool. Improved durability.
- Dedicated front & rear, reverse cup, high tensile steel, CVD driveshafts. Improves all round traction. Differential and spool plastic inserts “sliders”. Offer a lightweight, efficient driveshaft interface.
- Incorporating larger pins and joints, improves strength and durability.
- Lightweight foam bumper.
- High tensile spring steel pins.
- Purple alloy M3 nuts.
- Battery fixing with tape or optional battery strap.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Source: Red RC
#2 forbs
forbs
    MSUK Regular
  • MSUK Supporter
  • 1,857 posts
  • Gender:Male
  • RC Cars:hyper 7 black E, hpi firestorm flux, hobao monster pirate
Posted 24 January 2012 - 04:01 PM
tasty
#3 dancook97
dancook97
    Getting Started
  • Members
  • PipPipPip
  • 102 posts
  • Gender:Male
  • RC Cars:in signature
Posted 24 January 2012 - 06:06 PM
im not too in to TC's but that thing looks very nice :sweeeet:
#4 andryk
andryk
    Getting Started
  • Members
  • PipPipPip
  • 109 posts
  • Gender:Male
  • RC Cars:Nikko Evo 1:10, 1:14, Tamiya TT-01, Tl-01 RA, HoBao Pirate MT Sport, Cen GX-1 and more
Posted 24 January 2012 - 07:11 PM
Yeah i like the style of the cut mx.. something what ever the name of the car is but wouldn't that get onto the balance of the car?
#5 nitro taste bad
nitro taste bad
    MSUK Regular
  • Members
  • PipPipPipPipPip
  • 252 posts
  • Gender:Male
  • RC Cars:hpi baja 5sc
Posted 24 January 2012 - 09:39 PM
ooooooohhhh carrrbonnnnn :sweeeet: also will cost quite a lot too i think, and i really hope somebody rich makes it rally and bashes it :sweatdrop:
#6 Garry
Garry
  • Forum Staff
  • 21,655 posts
  • Gender:Male
Posted 25 January 2012 - 04:30 PM
£360.
#7 Garry
Garry
  • Forum Staff
  • 21,655 posts
  • Gender:Male
Posted 03 February 2012 - 06:42 PM
Modelsport UK
