scout re-steer conversion
  • Please log in to reply
12 replies to this topic
#1 simont
simont
    MSUK Regular
  • MSUK Supporter
  • PipPipPipPipPipPip
  • 490 posts
  • Gender:Male
  • RC Cars:scout crawler,losi comp crawler,Traxxas Summit
Posted 22 January 2012 - 09:03 AM
popped up to my local rc shop yesterday to collect some of the bits i'd ordered a few weeks back
for the scout
steering servo mount and steering arms
also picked up some misc servo mounting plastics and some servo arms and Y wiring kit
my theory being that i could piggy back the rear steer off the front using a Y kit but use the 3rd channel to cut the power to the
rear servo locking it in a position and just using the front then switching the rear on to use it again
so i mounted the plate onto the rear diff nice and easy as the scout use's the same axle front and rear the rear just having
lock out pins fitted,these i removed and fitted one side with a steering are( you get 2 in a pack for sum reason) then mounted the servo for now im just using a standard servo and i will have to fit a proper steering unit
it was just then a matter of fixing a 3rd servo into the elec tray of the scout easy job as the battery is now located on the front axle,this servo was plugged into the 3rd channel on the Rx,on my radio gear this is used to run say a switch for lights and the such,so again in my mind if i used the servo to work a standard switch i could cut the power so a switch was glued into the old battery tray with an old steering arm used from the servo to the switch to push and pull it off ..... it worked........
then it was just a matter of finding the best wire to break into on the rear steer servo to cut its power,i found the yellow to be the best
dont now why but hey...... so now the switch is spliced into the switches red wire,,,, as said i do need a stronger servo to run the rear axle maverick use a ms-25 on the fronts but i cant seem to find the same in their spares but  the ms-23 is metal geared so might give this a go
will post up some pix tonight
Simon
#2 landmaxdriver
landmaxdriver
    MSUK Regular
  • Members
  • PipPipPipPipPipPipPipPipPip
  • 1,766 posts
  • Gender:Male
  • RC Cars:See sig!
Posted 22 January 2012 - 09:29 AM
Sounds interesting :good:
#3 big gaz
big gaz
    Veteran Member
  • MSUK Supporter
  • 2,891 posts
  • Gender:Male
  • RC Cars:in my sig.......
Posted 22 January 2012 - 09:52 AM
looking forward to some pics mate :thumbsup:
#4 Syncro
Syncro
    Getting Started
  • Members
  • PipPipPipPip
  • 200 posts
  • Gender:Male
  • RC Cars:Tamiya Monster Beetle, Tamiya Celica, Axial SCX10, Wraith, CC01.
Posted 22 January 2012 - 10:26 AM
That's an interesting idea.
Good thinking.
#5 simont
simont
    MSUK Regular
  • MSUK Supporter
  • 490 posts
  • Gender:Male
Posted 22 January 2012 - 04:24 PM
rear servo mount
Posted Image
lock links removed and steering link fitted,had to swap it to other side thou
Posted Image
rear steer servo fitted and wired into the front steering servo with the Y lead
Posted Image
3rd servo fitted in old battery tray with the cut out switch fitted
Posted Image
side view
Posted Image
My m8 came over with his family and as i live next to the long mynd/ cardingmill valley
http://www.google.co...=1t:429,r:1,s:0
http://www.google.co...1t:429,r:2,s:45
it seemed rude not to use the local rocks to play on
neil bought his wraith and i took the scout up
the scout worked very well with the current mod's ive done few times has height issues so as thought think i need to fit 2.2 tyres to give me a bit move diff clearence
the rear steer and its cut out switched worked really well helping the scout crab and turn much better than i thought, but as expected the rear steer servo
took a bashing stripping its gears i think so as i said a proper steering servo is needed.
neils wraith works really well as a standard truck i think its wheel base helps it as its a bout 3" longer than the scouts
sorry no pics of the actuall crawling neil did film a bit but dont no if he can load it off his i phoo
Simon
#6 darknight
darknight
    MSUK Regular
  • Members
  • 706 posts
  • Gender:Male
  • RC Cars:speed passion rs2, losi night crawler/comp crawler/wraith / traxxas summit/super evolution!!
Posted 22 January 2012 - 04:41 PM
well, good idea mate, good to see some ingenuity, yea for steering servos i would say you need at least a good 15kg, i use much higher, all depends on the purse string,lol.
thats a lovely place, and a good crawling spot
#7 simont
simont
    MSUK Regular
  • MSUK Supporter
  • 490 posts
  • Gender:Male
Posted 22 January 2012 - 04:47 PM
purse  strings are rather tight at pressent lol but hope fully soon enuf good thing is all i need to do is re-fit the lock pins back on the rear axle and not worry
about till i can get a better servo
http://www.wheelspin...vo/?cs={1:[70]}
was looking at the ms=23m one???
#8 darknight
darknight
    MSUK Regular
  • Members
  • 706 posts
  • Gender:Male
Posted 22 January 2012 - 04:53 PM
to be honest mate for that price go for a savox 0252mg
#9 simont
simont
    MSUK Regular
  • MSUK Supporter
  • 490 posts
  • Gender:Male
Posted 22 January 2012 - 04:55 PM
Got more info DK?
#10 darknight
darknight
    MSUK Regular
  • Members
  • 706 posts
  • Gender:Male
Posted 22 January 2012 - 05:00 PM
errrrrrr yep its about 10-15kg and savox are a very good make   http://www.apexmodel...SAV-SC0252.html
Edited by darknight, 22 January 2012 - 05:00 PM.
#11 simont
simont
    MSUK Regular
  • MSUK Supporter
  • 490 posts
  • Gender:Male
Posted 22 January 2012 - 05:16 PM
looks good see wot i can get :o :thumbsup:
#12 neilswheels42
neilswheels42
    Just Registered
  • Members
  • 9 posts
  • Gender:Male
  • RC Cars:maverick blackout, traxxas summit,axial wraith, annsman moto-x bike
Posted 23 January 2012 - 06:28 PM
:thumbsup: was ace day out with si, and was very impressed with his scout. :thumbsup:
cant wait for the next meet up again, could do with a few more there and have a proper "rock crawler meet" :insane:
#13 simont
simont
    MSUK Regular
  • MSUK Supporter
  • 490 posts
  • Gender:Male
Posted 24 January 2012 - 10:13 AM
neil
did you manage to get the footage off ya i poo from sunday?
Si
Modelsport UK
