A Hyper 12 Mini ST, it came with everything needed for nitro except engine ETC .... so was nearly ready to run,
BUT
I didn't want to run it as nitro and i'm more of a leccy kinda person..
as i wont be getting the electrics and motor mount for a while as i have spent quite a bit this month already,
so out came my bodging skills...
I took an old video case and started cutting it up, added some shoe goo and drilled some holes and it was done.
now my main problem was there would be no where to put the esc once bought, so i went for a search and found some perspex,
got the hacksaw to it (more bodging) drilled 4 holes and mounted... it has a curved side to it, but once the esc is mounted you wont notice it ( i will end up getting a diff cover/plate like on the hyper 10tt.
I ordered some battery straps and some 5,000wt and 7,000wt diff oils for the diffs and started to strip it down and re-oil, mounted battery straps.
It is now ready for the conversion
Edited by AlexBruv, 16 February 2012 - 09:50 PM.
