was getting a losi comp crawler now got an axial xr10
  • Please log in to reply
46 replies to this topic
#1 paul-n
paul-n
    Just Registered
  • MSUK Supporter
  • Pip
  • 47 posts
  • Gender:Male
  • RC Cars:tamiya pajero axial xr10 hpi baja ss
Posted 29 December 2011 - 08:53 PM
Hi all, just a quick question,i'm thinking of getting a losi comp crawler but haven't found any info on choosing a suitable motor,esc,servo's and radio. so what do i need and how much will it cost?
Edited by paul-n, 29 January 2012 - 11:11 AM.
#2 domcharlton
domcharlton
    Veteran Member
  • MSUK Supporter
  • 2,046 posts
  • Gender:Male
  • RC Cars:Axial SCX10, Losi Comp Crawler, Losi 8e Tekno V4, Hyper 7E, Hong Nor CRTe, HPI Blitz
Posted 29 December 2011 - 11:32 PM
You will need a Brushless system for it because the Worms gears will kill brushed motors quickly.
You need something 17t or higher Novak and Tekin are good.  (£150 ish)
For a radio i'd go for a DX3C because you can run the dig from that as it has three channels and 3 pos switch (you can also use it with other cars as it has model memory)  (£70)
Servo you need something high torque at least 15kg. (Savox 1256 or similar) (£50)
Crawling aint cheap. :thumbsup:
#3 darknight
darknight
    MSUK Regular
  • Members
  • 706 posts
  • Gender:Male
  • RC Cars:speed passion rs2, losi night crawler/comp crawler/wraith / traxxas summit/super evolution!!
Posted 30 December 2011 - 08:06 AM
exactly as above mate, you can pick up a comp on fleabay for 85 quid now as its being discontinued !! but deff go for the novak goat system and you need the 3 channel rx so you can operate the dig
Edited by darknight, 30 December 2011 - 12:38 PM.
#4 big gaz
big gaz
    Veteran Member
  • MSUK Supporter
  • 2,885 posts
  • Gender:Male
  • RC Cars:in my sig.......
Posted 30 December 2011 - 10:45 AM
you could go for a 32t ezrun combo for it which will work very well, not quite as good as the novak for around the £60 mark. servo, as above, savox 1256tg or a ace ds1015. either would be pefect!!
lastly, radio gear, basically, any which you can afford but the 3rd channel needs to be a 3 way switch type. dom pointed out the dx3c which would be fine or you could go for the slightly older but still a damn fine radio, the dx3e.
good look with whatever you go for,  i will say, money spent now, will save in the long run, especially on the servo mate.
cheers, gaz.
#5 paul-n
paul-n
    Just Registered
  • MSUK Supporter
  • Pip
  • 47 posts
  • Gender:Male
Posted 30 December 2011 - 10:44 PM
thanks for the help guys :D will it be a problem getting spare parts if it's discontinued?
#6 darknight
darknight
    MSUK Regular
  • Members
  • 706 posts
  • Gender:Male
Posted 31 December 2011 - 06:46 AM
na, its the same basically as the nightcrawler, apart from the dig and the hop ups the nc dont have, all those parts are available as hop ups for the nc, the news is they are continuing in rtr form as the comp isnt doing well now in comps!
#7 jabba1
jabba1
    Getting Started
  • Members
  • PipPipPipPip
  • 233 posts
  • Gender:Male
  • RC Cars:xr10,hyper 7e,scrt-10,tc4,tt01.e-maxx
Posted 31 December 2011 - 07:32 AM
Hi mate if you go brushless make sure its sensored,if not it will cog at low speed.
jabba.
#8 paul-n
paul-n
    Just Registered
  • MSUK Supporter
  • Pip
  • 47 posts
  • Gender:Male
Posted 01 January 2012 - 10:36 PM
really apreciate all the help so far guys,thanks!
so far in my modelsport basket i've got the dx3e transmitter,losi 11.1v 1350mah 3s battery(recommended on the comp crawler page)
and a savox sc 1256 servo.
i found the comp crawler for £85 so that's sorted :good:
just need to find the best(cheapest) place to get the motor and esc.I looked at the modelsport recommended speed passion one and the novak goat but they appear to be only for 2s lipos so i'm confused why they'd suggest a 2s esc and a 3s battery?!
Next question is servo and battery compatibility,will the savox servo be ok on 11.1v?
#9 darknight
darknight
    MSUK Regular
  • Members
  • 706 posts
  • Gender:Male
Posted 02 January 2012 - 07:44 AM
Welli must admit im happy with a 2s lipo,  gives good runtimes and is compatible with what i use and where.
There is a lot of confusion/difference of opinionon brushed/brushless, but i have used a titan 550 monster, for about a year with no probs at all, it was wet run in. Also i know a lot that does, the opinion is that the worm gear destroys the motor, which is true but most i know can run one easilly for a year.i would probably go with big gaz sugestion of the ezrun or a titan motor.The servo is good, i had a smaller one and it bust too quick.
Some people like the newer dx3 as you can see easier where you have set your dig, forward/ back/ 4wd. But thats just personall, just letting you know.
A good upgrade straight from the box would be a diff set of wheels, the tyres are fine, but the standard wheels are verry shallow dish inside, so when i put lead in to weight them you can only get about 3 oz per wheel before pushing out to far, jc concepts,vantage etc all do a deeper wheel recess for that reason.
Go for around 6-7 oz in each front and half on the back, also  soften the springs in the front, and a bit harder in the back dont need new springs just adjust the standard settings for now.
Star cut the foams also..
Oh by the way if you find it does " cog" up, just engage disengage dig it will then release just fine
#10 domcharlton
domcharlton
    Veteran Member
  • MSUK Supporter
  • 2,046 posts
  • Gender:Male
Posted 03 January 2012 - 11:02 PM
If you have still not sorted a combo yet you can buy a Speed Passion 1000kv combo for £50 from Ebay!
#11 paul-n
paul-n
    Just Registered
  • MSUK Supporter
  • Pip
  • 47 posts
  • Gender:Male
Posted 05 January 2012 - 05:21 PM
Theres been a slight change of plan! I bought a axial xr10 instead
#12 darknight
darknight
    MSUK Regular
  • Members
  • 706 posts
  • Gender:Male
Posted 06 January 2012 - 06:35 AM
ha ha lol, ah well all you need is about 800 quid for upgrades now ;)
#13 paul-n
paul-n
    Just Registered
  • MSUK Supporter
  • Pip
  • 47 posts
  • Gender:Male
Posted 08 January 2012 - 09:53 PM
what upgrades do you suggest?i know the axle gears are a weak point on them.
i got the kit new for £90 and so far i've ordered proline chisel tyres,high torque servo,30 degree bent arms and an electronic dig.Just got to choose 2 motors,2 esc's,a lipo and charger
#14 big gaz
big gaz
    Veteran Member
  • MSUK Supporter
  • 2,885 posts
  • Gender:Male
Posted 08 January 2012 - 10:04 PM
i would go for either novak/tekin 45t or 55t for the motors and either novak rooster crawler or tekin fxr for the esc, both esc`s will happily run 2 motors that i listed with no worries.
yes first job is the gearbox bearing mods, maybe alloy knuckles and c-hubs on the front and a alloy steering link, otherwise they are quite a good crawler mate. :thumbsup:  :thumbsup:
#15 paul-n
paul-n
    Just Registered
  • MSUK Supporter
  • Pip
  • 47 posts
  • Gender:Male
Posted 08 January 2012 - 10:30 PM
Thanks,i've read that the tekin motors are good but as im planning fitting this http://www.teamnovak.../dig/index.html i need 2 esc's so i may get 2 mtroniks tio rock crawler esc's if they are ok,i'm going see if i can find some reviews on them before ordering them
Modelsport UK
