I started off with a donor car, being my Thunder Tiger DX which i got ages ago and it never really found it's place
With a lot of help from Martin (pieman5) i found out that his car (ftx blaze) is the same width as the average touring car but a lot shorter. So a new chassis is in order!
I did a few measurements and drew a little plan on paper then put the front and rear ends of the donor car to see how it fits
Looked pretty good!
(the battery is a 3s lipo from my rascal conversion and the motor from the mini lst)
So I then was stuck with what shell to get. I was reccomended (Martin again
It arrived on friday and i loved it! which one did i order i here you ask? well i decided to get this one
It's a mini shortcourse shell!!!
However it turned out that the shell is 10mm shorter than i anticipated so that means i had to take 10mm off the chassis for it to fit.
And because of this my 3s lipo won't fit so i will be needing smaller ones.
I then thought all good projects need a model/template so i got about making one with a sheet of aluminium, then offered the parts of the car up to it.
i think it turned out alright, and because now i have a basic mock up, i can see if the shell fits, which it did!
Next step will be fabricating the proper chassis and also a centre driveshaft (need 4wd for powar!!!)
What do you guys think?
Edited by ReggieC, 01 January 2012 - 09:18 PM.
