Quote
Get ready for some serious off road truggy action with the Brushless Edition FTX Carnage. Taking backyard bashing to a new level, the Carnage Brushless boasts some amazing features for the ultimate ‘Ready-to-Run’ experience.
Etronix provide crystal free 2.4ghz control with the EX2 Sport radio. In addition the Etronix Photon sensorless brushless system is installed to provide some low maintenance, high performance speed and power.
Instead of using a NiMh battery, FTX decided to include a Voltz hardcase LiPo battery to get the very best from the Photon system, but with safety in mind included is a balance charger and LiPo charge sack. Infact all you need to add is AA batteries for the transmitter.
The 4wd shaft drivetrain features metal diff gears and front universal driveshafts, while an integrated slipper helps protect the drive from possible damage. With adjustable turn- buckles all round and large bore oil filled shock absorbers the Carnage is raring to go.
In addition if you want to tune and upgrade your Carnage, FTX provide a wide range of car- bon and aluminium upgrades that will bring your ride up to a whole new pro level.
Features:
Ready to run
Etronix EX2 Sport 2.4ghz radio
Etronix 60Amp Photon sensorless brushless speed control
Etronix 3930KV sensorless brushless motor
Etronix Pocket Balance charger
Voltz 2700mah 7.4v 25c LiPo Hard cased
Big bore oil filled adjustable shocks
Gearbox metal crown & pinion gear
Front universal driveshafts
Adjustable wheelbase
Adjustable turnbuckles
Fully adjustable suspension including, droop, [*]camber, toe-in, wheelbase etc
Slipper for drivetrain damage protection
Voltz LiPo charge sack
Race designed low profile pre-painted bodyshell
Chassis accepts NiMh or LiPo battery
3kg steering servo
Moulded tub chassis body
4wd shaft drive with slipper system
Unique gearbox design for low CG
Lightweight high impact arms
Wide range of option parts available
Specification
Length: 415mm
Width: 328mm
Heigh: 156mm
Wheelbase: 290/295mm
Tyre: ø 120 x 60mm
Gear Ratio: 11.2:1
FTX5543 FTX Carnage 1/10 4WD Brushless Truggy RTR £209.99
Source: CML
