classic Posted December 2, 2006 Share Posted December 2, 2006 hello , i would like too know how too look my diffs as i am wanting to do some drifting ..... and would they have some instructions with some pictures ... also after i have locked them i want a way to unlock them easily my chassis is a tt01 thanks alot , vinny Quote Link to comment Share on other sites More sharing options...
Michael. Posted December 2, 2006 Share Posted December 2, 2006 (edited) One way to semi lock your diff, is to fill it with vaseline. You can easily change it to unlocked again, and if your using drift tyres, you won't notice the difference between a vaseline locked and fully locked diff Edited December 2, 2006 by Michael. Quote Link to comment Share on other sites More sharing options...
Hpi_matrix_stock Posted December 2, 2006 Share Posted December 2, 2006 You could try blue tack if you want aq temp job, would be hard to clean out after though. Quote Link to comment Share on other sites More sharing options...
Garry Posted December 2, 2006 Share Posted December 2, 2006 I've got Blu-Tac in mine, they stay locked fine unless you do doughnuts (fun for about 20 seconds). If I were you, I'd buy the bits needed to make another pair of diffs and lock those up, so you'll have a pair of locked ones and a pair of standard ones ready to drop in and use. Quote Link to comment Share on other sites More sharing options...
classic Posted December 2, 2006 Author Share Posted December 2, 2006 good thinking Quote Link to comment Share on other sites More sharing options...
arris Posted December 2, 2006 Share Posted December 2, 2006 use something like jb weld if it permantly, this is what i have seen mostly used, or any 2 part like metal epoxy Quote Link to comment Share on other sites More sharing options...
spudmurphy Posted March 1, 2007 Share Posted March 1, 2007 what part of the diff or diffs (front and rear?) should I be sticking together to lock them? And also how much of a difference does it make, I've been drifting my TT01 for a while now, starting to get the hang of it pretty well, will this make much of a difference? Ta Quote Link to comment Share on other sites More sharing options...
Garry Posted March 1, 2007 Share Posted March 1, 2007 Kinda hard to explain, hope these pictures are clear enough. Standard diff: Blu-tacked diff: Basically, all the teeth-to-teeth faces on the inside of each diff needs blu-tacking. The more you put in, the longer the effect lasts. Remember to wash the grease out first! Quote Link to comment Share on other sites More sharing options...
leegsi Posted March 1, 2007 Share Posted March 1, 2007 Easy way to do the TT-01 is move one of the cogs, See where the 3 MA13's are.........Just remove one and place it between the other two. That way they try to turn agaist each other and lock the diff. Quote Link to comment Share on other sites More sharing options...
Brucie Posted March 1, 2007 Share Posted March 1, 2007 I agree with the blu-tac for locking these diffs on the TT and the TL diffs. They should stay locked if they are well packed in the first place and you can unlock it just as easy as you locked it. I'd suggest locking the rear and putting a one way unit in the front. Brucie. Quote Link to comment Share on other sites More sharing options...
kroozin Posted March 2, 2007 Share Posted March 2, 2007 garrys pics would help but i dont just do that i stuff the B@^$!*D so full the end nearly pops off mines stayed locked for ages, i have a tl-01 Quote Link to comment Share on other sites More sharing options...
carsey Posted March 2, 2007 Share Posted March 2, 2007 My bluetacked diff on my TT-01 has stayed solid since it was locked. Quote Link to comment Share on other sites More sharing options...
Michael. Posted March 3, 2007 Share Posted March 3, 2007 Just locked my Twin Detonator diff in the way that Leegsi suggested- it works great, no hassle or mess, and will be as strong as the stock diff was. Don't bother with bluetack, just put one of the small bevel gears (MA13) in between the other two, and put the diff back together as normal. Quote Link to comment Share on other sites More sharing options...
smithy1135 Posted March 5, 2007 Share Posted March 5, 2007 I use the Blu-Tac method and it works perfectly, no hassle at all really, and very easy and quick to do... Quote Link to comment Share on other sites More sharing options...
lewp91 Posted December 8, 2007 Share Posted December 8, 2007 i get 2-3 mm of pipe for the fuel and put it on the bar at the end of where the small gears go it ushes them tighter n causes friction locking the diff n depending on how much you use eg 3mm will lock 2mm will tighten works great n so quick to take out if u wanna grip again laters n any feedback for my first post? laters lew Quote Link to comment Share on other sites More sharing options...
joe of loath Posted December 14, 2007 Share Posted December 14, 2007 ok, tip the oil out, and fill it with hot glue! then to unlock it agian, simply peel it out. the residue oil will mean it won't stick. Quote Link to comment Share on other sites More sharing options...
rockers Posted December 14, 2007 Share Posted December 14, 2007 quick answe Classic does not have a car anymore ... but good for others to see Quote Link to comment Share on other sites More sharing options...
