[REDUCED 19/07] Nitro Engines & Spares//Chargers//Hong Nor CRT Spares//Shocks//Truggy Wheels&Tyres//Servos//Hyper Spares
mayzie12
All Prices Include Fees, But Not Postage.
I will only post items recorded delivery.
First up All Generic Spares
Glow Starter Charger, Specs as Picture
£2
Thunder Tiger Glow Starter Charger, Specs as Picture
£2
Futaba Ripmax Hump Pack Charger, Specs as Picture. Has ends to charge packs with Futaba Plug.
£2
Tornado After Run Oil, Virtually Full
£1.50
Job Lot of Linkages/Collars/Springs for Nitro Cars. Tonnes of handy little bits to keep you going
£5.00
Clutch Bells, 16T, 17T and 18T. Inner diameter on all of them is around 21mm
£1.50 each
Fuel Coolers
50p each
Exhausts. Bottom is unmarked and dented as per the picture. Middle is a Hyper exhaust OK, condition. Top pipe is a RB pipe i believe, again has a dent in it.
Unknown £3, Hyper Exhaust £4, RB Pipe £5
PTXSlwD.jpg?1
DLLLi35.jpg?1
Hyper 21 8 Port Nitro Engine
Came in Job Lot, never tried to run it. Still turns fine albeit a bit stiff, so sold as spares
SOLD
Novarossi 421B Nitro Engine.
Again, Came in Job Lot, never tried to run it, hence sold as spares. Turns no problem.
£15
Servos. All fully working.
Hi-Tec HS645MG £6. Hong Nor HNS-2 £3 Each. Futaba S3003 £3.
Pair of Shocks.
Around 105mm total legnth. £3
Pair of Shocks
Around 125mm total length £3
Pair of Shocks
Around 140mm total length £2
I4h4Jf4.jpg?1
Wheels and Tyres
Set of 4 Truggy wheels and tyres. No Markings at all. Still  plenty life left. Ready to be used
£13
Set of 4 Hong Not Truggy Wheels and Tyres. Foams feel soft but intact
£12
Set of 4 Hong Nor Truggy Wheels and Tyres. Foam has gone in 3 of them, would need new foams.
£9
All Hyper Spares
Engine Mounting Plates
£1 Each
Front Shock Towers
Seem thicker than stock, 4mm thick.
£2.50 Each
HnRPixh.jpg?1
Hyper 7 Diffs.
One on the left seems to have a block bolted on to allow wider upper arms, can be removed as its just screwed on. Each diff gets the extra peice sitting in front (wing mount and upper arm mount) They have not been rebuilt so will need cleaned out and filled with oil of choice
£7 Each
ALL Hong Nor Spares
Hong Nor Wings. Yellow one has a couple of small cracks where the two winglets meet, can be seen in pic.
£1.50 Each
Hong Nor X1 CRT Brake parts.
Sold as £5 a set (4 pads, 2 brake cams and 2 discs) or £20 for the whole lot.
X1 CRT/CR Knuckles
£3
Another pair of X1 CRT/CR Knuckles
£3
X1 CRT Receiver boxes ( i think they were used the same on buggies) Most have switches and the rubber covers (Not guaranteeing you will get one with as i have not checked the switches anyway)
£1.50 each
X1 CRT Fuel Tanks
£3 each
X1 CRT Mudflaps
£2 Each (Pair)
X1 CRT 62T Spur Gears and Centre diff with 62T spur
£6 Each Spur Gear. £10 for Centre Diff with Spur gear
X1 CRT Lower Arms (Front)
£4
X1 CRT Lower Arms (Rear)
£4
X1 CRT Upper Arms (Front)
£3.50
£2.50 Each
X1/2 CR/CRT Centre Diff Mounts
£1 Each
Edited by mayzie12
