53HRA Posted May 5, 2016 Share Posted May 5, 2016 Reedy Blackbox 1000Z+ Competition ESC Reedy's Blackbox 1000Z+ is a simple-to-use, economical, and powerful ESC that features timing options for Modified class racers as well as zero-timing blinky mode for Spec class racers. Excellent throttle and brake feel, a wide range of adjustability, and robust hardware make the Blackbox 1000Z+ suitable for a variety of racing applications! Features: - Lightweight plastic case with compact footprint - Heat sink with cooling fan - Fully adjustable brake and throttle functions - On-board, single-button programming - Zero-timing ROAR-approved software - Timing options for Modified racing - Low-resistance circuitry - Precision throttle and brake control - Solder tabs for easy wire placement - 13-gauge power wires - Compact external capacitor board - Firmware updateable - Competition proven Adjustable Settings - Drag Brake - Adjust automatic braking strength when the throttle trigger is returned to neutral. - Brake Frequency - Create a smoother or more aggressive brake feel. - Maximum Brake Strength - Increase or reduce the ESC's maximum braking power. - Power Profile - Increase or decrease "punch." - Drive Frequency - Create a smoother or more aggressive throttle feel. - Timing - Select the amount of timing fed to the motor to increase power and top speed. - Operation Mode - Select Forward/Brake (F/B) or Forward/Brake/Reverse (F/B/R) operation. - Restore Default - Restore the factory default settings Source: Teamassociated View full news article Quote Link to comment Share on other sites More sharing options...
