Bunny_Basher Posted January 17, 2016 Share Posted January 17, 2016 (edited) Okay, what options are there for an aftermarket pipe to fit the Mini WRC? Has stock Dynamite 29cc engine Stock body/cage Not fussed about finish of the pipe (chrome/raw) I've checked out all the usual UK 5th scale suppliers and from what I can see there is a very very limited range of pipes available. So all you fellow Mini WRC owners what have you fitted? I was hoping to fit a Samba pipe that I recently removed from my 5ive T, but it's just a bit too long and fouls the LH rear wheel Edited January 17, 2016 by Bunny_Basher Quote Link to comment Share on other sites More sharing options...
scatteh316 Posted January 17, 2016 Share Posted January 17, 2016 Losi Tuned Pipe is very very good for the money..... But it's loud..... So be warned.. Quote Link to comment Share on other sites More sharing options...
(-:AD:-) Posted January 17, 2016 Share Posted January 17, 2016 Bzm fits well and it's a great pipe! Quote Link to comment Share on other sites More sharing options...
Leo Posted January 17, 2016 Share Posted January 17, 2016 I use the Bartolone pipe with mine, there's also the Victory RC pipe. Be warned though, the Losi Tuned pipe also exits too close to the rear wheel. http://www.davesmotors.com/Bartolone-Racing-Losi-Mini-Cooper-Tuned-Pipe-Black.html http://www.davesmotors.com/fd936a-victory-rc-unsilenced-pipe-losi-mini-WRC.html http://www.davesmotors.com/fd936b-victory-rc-silenced-pipe-losi-mini-WRC.html Quote Link to comment Share on other sites More sharing options...
RCbutcher Posted January 17, 2016 Share Posted January 17, 2016 So losi 5t pipes won't fit the mini 5 as normal? Why is this? Quote Link to comment Share on other sites More sharing options...
supersavage Posted January 17, 2016 Share Posted January 17, 2016 24 minutes ago, RCbutcher said: So losi 5t pipes won't fit the mini 5 as normal? Why is this? I assume it's because the mini has a narrower wheelbase (shorter suspension arms). Quote Link to comment Share on other sites More sharing options...
(-:AD:-) Posted January 17, 2016 Share Posted January 17, 2016 Also the cage is different... tall pipes don't fit. They touch/hit the cage. Quote Link to comment Share on other sites More sharing options...
Bunny_Basher Posted January 18, 2016 Author Share Posted January 18, 2016 BZM it will be, I dry fitted the one from my 5ive T, result Also, if (or do I mean when!), I get another SCZ, the pipe will be a good match to the new engine. Quote Link to comment Share on other sites More sharing options...
Leo Posted January 18, 2016 Share Posted January 18, 2016 2 hours ago, Bunny_Basher said: BZM it will be, I dry fitted the one from my 5ive T, result Also, if (or do I mean when!), I get another SCZ, the pipe will be a good match to the new engine. Just remember the big stock air filter won't fit under the cage when you fit a reed engine. Quote Link to comment Share on other sites More sharing options...
norcoforever Posted January 22, 2016 Share Posted January 22, 2016 Also the jetpro rear mount pipe fits perfectly Quote Link to comment Share on other sites More sharing options...
Bunny_Basher Posted January 23, 2016 Author Share Posted January 23, 2016 As earlier post, I purchased another BZM pipe, fits perfectly and is not too loud 1 Quote Link to comment Share on other sites More sharing options...
Bunny_Basher Posted January 24, 2016 Author Share Posted January 24, 2016 (edited) Here's a quick video of my first run with the mini. Exhaust is slightly louder than a SAMBA, deffo louder than the stock muffler, but really not that bad. I soon discovered that wet grass and the Mini tires don't give much grip Losi Mini stock engine, BZM exhaust, first run Edited January 24, 2016 by Bunny_Basher Quote Link to comment Share on other sites More sharing options...
sean-vrs Posted January 24, 2016 Share Posted January 24, 2016 Quote Link to comment Share on other sites More sharing options...
atom3624 Posted January 24, 2016 Share Posted January 24, 2016 Did you find it overheating? Just curious why you cut so much out of the body. My personal preference is not to at all, or to cut 'in a scale manner' - part-way down windows, etc. Al. Quote Link to comment Share on other sites More sharing options...
Bunny_Basher Posted January 24, 2016 Author Share Posted January 24, 2016 Body is totally stock/standard. My first thought was that the 'missing' windscreen is for access to the mechanicals as much as airflow to cool the engine. Having said that the body has no cut out at the rear to access the pull starter, so you have to remove the body every time to start it. Remember - this car was originally designed to be and was released prefitted with an electro starter, so likely that Losi decided that the missing windscreen option was a solution to prevent overheating. They have done the same on the 5ive T, with a huge hole where the windscreen should be. Quote Link to comment Share on other sites More sharing options...
(-:AD:-) Posted January 24, 2016 Share Posted January 24, 2016 The ones I have seen all have a cut out for the pullstart Quote Link to comment Share on other sites More sharing options...
atom3624 Posted January 24, 2016 Share Posted January 24, 2016 Looks like the cut-out is squared, not round - not ideal either really. Thanks for clarifying. Al. Quote Link to comment Share on other sites More sharing options...
mickturnip Posted January 24, 2016 Share Posted January 24, 2016 19 hours ago, Bunny_Basher said: Here's a quick video of my first run with the mini. Exhaust is slightly louder than a SAMBA, deffo louder than the stock muffler, but really not that bad. I soon discovered that wet grass and the Mini tires don't give much grip Losi Mini stock engine, BZM exhaust, first run Do you have a link to wher u got the exhaust ...cheers Quote Link to comment Share on other sites More sharing options...
(-:AD:-) Posted January 24, 2016 Share Posted January 24, 2016 Mmr model tech sell them Quote Link to comment Share on other sites More sharing options...
Bunny_Basher Posted January 24, 2016 Author Share Posted January 24, 2016 14 minutes ago, mickturnip said: Do you have a link to wher u got the exhaust ...cheers http://www.mmrlargescale.co.uk/acatalog/RCB8800.html Quote Link to comment Share on other sites More sharing options...
Bunny_Basher Posted January 24, 2016 Author Share Posted January 24, 2016 4 hours ago, (-:AD:-) said: The ones I have seen all have a cut out for the pullstart You're right it does have a square hole cut in the LH rear - but I can barely fit my hand through it and if you extend the pull cord enough to get the handle clear the body, its already over 50% pulled. Quote Link to comment Share on other sites More sharing options...
